How to get the bike in the garage??
#31
The gas hot water heater is the big white thing setting up in the alcove.
#32
HA!! I GOT IT!!
Oh lawdy I'm so pleased with myself. So you guys literally gave me some terrific ideas! I started thinking about how to get rid of the lip and I realized I had some truck bed ramps that were the exact height of the lip. Using those, they gave me just enough extra room to wiggle the bike around. That combined with turning the bike around made it for perfectly.
You guys are literally the best. I couldn't have done it without you all!
Kevin
Kevin
#33
Well the florida sun is killer on vehicles, along with the sandy breezes I get quite frequently around my house. I have quite a bit invested in the truck as well, so getting inside was a must. Not to mention, morning due all over my windows in the morning drives me bat sh*t crazy haha.
I fail to see the issue with the water heater though. Perhaps someone can explain that one to me. I'm not going to start the bike up ever where it is. It's going to be rolled back and out of the way, which will of course be after the truck has been backed out which of course requires the garage door to be open. Sooo... Issue? I fail to see one.
If it does explode with terrorist proportions, it'll just be me though, no family to worry about. Maybe the stray cat or two outside will get singed but I don't think anyone will mind too much :P
#34
I think they're referring to the vapours from your tank building up enough to explode...which in my opinion is very unlikely. It's not a confined space so anything that gets outside the tank will dissipate quick enough and inside the tank doesn't have enough oxygen to support combustion. Now I wouldn't leave the gas cap off and park it there or fill it with gas while in front of the water heater so just some common sense and you will probably be fine.
Besides don't most water heaters have flame arrestors to help prevent this type of thing?
#35
Your bike is EFI? It is equipped with emission control equipment that eliminates most if not all gas vapors while engine is off. I would not worry about the water heater. Hell, your truck probably vents more vapors than the bike.
And, you have belt drive, so no cleaning the chain with gasoline inside the garage to worry about.
John
John
#36
John
John
#38
You have 4.5 gallons of gasoline inches away from a continuous pilot light, and at times, a much larger flame when the burner is on.
- 1 gallon of gasoline contains 1.3 x 10^8 Joules of energy. (130000000 J)
- 4.5 gallons contains 5.85 x 10^8 Joules. (585000000 J)
- 1 kg of TNT exploding releases 1 x 10^6 Joules. (1000000 J)
If that gas tank were to explode, it would do so with the equivalent energy of 585 kg (1290 lb) of TNT.
Hence the explosion of terrorist proportions mentioned earlier. This won't be 'honey, get the fire extingusher!' - It will level your house and maybe one or more of your neighbors' houses, depending on how big the lots in your subdivision are.
BTW - I'm an engineer; many of my designs include pressure vessels, stored energy and varying explosion risk - I work with math and physics like this all the time.
#39
#40
You are correct. In cases like mitigating/managing explosion risk, worst case scenarios are what are reported, and what systems are designed to withstand. Managers don't listen if we say there may be a fire.
The NASA engineers grounded what turned out to be Challenger's last flight - they were overridden by managers who were more concerned with the TV crews filming the first civilian, also a school teacher, going into space. The managers later blamed the engineers for not scrubbing the launch. 24 engineers quit their NASA gigs over it.
Depending on how an incident could occur, for example, the fuel tank vent tube igniting and that flame flashing to the tank, the vaporization could occur in seconds. Especially with the help of the extreme pressure that would be created inside the tank, which would blow the tank wide open. There would be more risk of explosion the less full the tank is, actually. Any scenario would likely produce a large fireball.
