Forty Eight 23mpg!?
Forty Eight 23mpg!?
I'm lost and I've looked all over the forums and found a dude with the same issue but his thread just stopped and no one is replying on it.
I took my Forty Eight in for it's 5000 mile service and when I got it back I noticed I'm only getting about 23-24 mpg. No using the light I'm getting 39mi to about 1.8 gallons of gas. I was getting about 38 to 40 in the city.
There is no fuel leak. I'm going to replace the spark plugs but can bad ones hurt fuel this much? Tire pressure good and I put 93 octane in it. I've made sure the breaks aren't riding.
I have:
Vance Hines two to one (no O2 sensors).
Power commander V (nothing crazy tune)
Stage 1 Air
I have noticed every now and then it sounds like it trying to suck air like a (phhh tummmmm) sound one time it even died but started back up. It has been a slow start lately but I just figured because of the colder weather.
Any help or just things to look for. I'm completely lost. I don't know why it would be fine and just all of the sudden bad with no noticeable ride difference.
I have:
Stage 1 Air
I don't believe it's the tuner but I don't know what it would be. Since nothing changed but the 5000 mile service and since he already installed the same tune that worked fine before service. Seems like something was done during service but I don't have the experience to know what it would be. But based on logic I don't see it being the tune. Since you said that the breather doesn't sound right, I would pull it and check the filter. Also check the intake opening to make sure it's clear and moving freely. If that all checks out I would make sure all of your connections to the pcv are secure and connected properly. Just to make sure they didn't disconnect and/or reconnect something wrong. Only other thing I can think of is to verify that you don't have an exhaust leak. Outside of that I don't know.
Take the PCV off for a tankful and see what you get. (I think you should be able just to disconnect the power for the PCV rather than disconnect everything.)
It will run lean but shouldn't hurt for just one tank of fuel. Check you mileage for that tankful, then you'll know if it's your tune, or something else.
Easy and simple.
Easy and simple.
Valleyofthegun
16
01-27-2019 07:27 AM
