Dyna battery in a sportster??
Hello, my 1993 Sportster sat a little too long, and the old battery has died and wont take a charge. I have a battery from a dyna in my garage that a friend no longer wants, can I use this battery?
It is the exact same size as my sportster battery and from what I can tell most aftermarket sportster batteries have more CCA than this dyna battery (315). Please let me know if this is a terrible idea or if others are running dyna batteries in their sportsters?
If that battery fits you'll be fine! As for your flashers, I don't think your bike has any fuses, only circuit breakers. They heat up and cut out if the circuit heats up due to a short or overload, but reset when cooled down. It's more likely your flasher unit is defective, or there is an electrical fault. Check the wiring for the flashers and flasher unit.
John
commandozx
10-02-2021 03:03 AM
Messedupalready
08-25-2014 09:53 PM
