baffles for Vance and Hines short shots staggered
Just installed Vance and Hines short shots staggered exhaust on my 04 Sporty. I also installed Vance and Hines VO2 breather. Bike sounds loud as expected but I'm considered adding quiet baffles. I was told the sound of the exhaust would be deeper and actually add more torque. My question, has anyone actually installed vance and hines quiet baffles? How quite do the pipes get? Is it worth the trouble?
plenty of posts about this topic all over the internet, but I'll answer anyways.
I have them installed, add a little more torque though nothing to brag about, pipes are not a lot more quieter, but not embarrassing anymore "matter of opinion", have deeper tone at idle that sounds good, just slightly deeper at higher rpm's but not a huge difference.
I think it's worth the trouble, and I'll be adding more baffle within the quiet baffle some time when i have time to get them how I want since I have a welder I can use at work.
https://www.hdforums.com/forum/dyna-g...affle-mod.html
I did this to my shortshots on my old street bob and it mellowed the sound out a bit. I don't think it made the note deeper, but it cut out some of higher end, so it appeared to be deeper. It also cut down on the decel pop a bit. Worth a try for a few bucks.
Might or might not satisfy you, but if it does work, it's a bit cheaper than buying baffles. Also, you didn't mention any type of tune. With open pipes and a/c, you might be a bit on the lean side.
I just installed quiet baffles in my short shots and as everyone says, there's little difference in sound. Much more mellow at idle for sure. I got them mostly to get rid of the decal popping and it seems to have noticeably done that. It only took a couple of miles of riding to hear the difference. I actually ran a decibel meter app on my iPhone and put it at 5ft from the rear of the bike.
Stock V&H Baffles-
Idle at run temp- max 96dB with an average of about 93dB
2100rpm at run temp- max 99dB and average of about 98dB
Quiet Baffles
Idle at run temp- max 94dB and average of 91dB
2100rpm at run temp- max 97dB and average of about 97dB
There are plenty of videos and threads available with before and after as well as side by side comparisons but video cameras just don't quite capture the audio enough to give you a feel for it which is why I wanted to use the decibel meter. So, yeah, not much difference overall but the improvement in decal popping was what I was after anyway.
Stock V&H Baffles-
Quiet Baffles
Detroit Iron
04-10-2019 01:14 PM
Jessica Sinclair
11-23-2017 01:19 PM
