2013 883 LED Signal Issues
Ok I have installed some RSD Tracker LED front and rear turn signals. The site says they are "single function" but they have 3 wires. Running / Power and Ground.
I finally got the power back on the bike tonight and for some reason the running portion is not working. The bike has a Run / Brake / Turn module stock and I would like for that to work again.
I have three problems.
1. The running lights are not working. The brake lights come on when pressed the turn signals flash when pressed.
2. When the turn signals are pressed left or right not only does the one pressed flash but the other flashes too but at a lower intensity.
3. When the brake lever is pulled the front right turn signal illuminates.
Any help with this would be greatly appreciated.
I know I will probably need a load equalizer and possibly if this doesn't work a Run / Brake / Turn module.
