You can buy any length of universal brake line you want from Goodridge or Magnum and get the propper banjo fittings to attach to the abs module and the master cylinder. I used a goodridge line on my Slim when I installed the 16" apes. Bleed the brakes with a vac bleeder and then have the abs reset by the dealer...only 1/2 hour labor.
why is it that the universal brake line would work with the lower part (oem) than a abs brake line from magnum?
