2015 1200x cat. removal
Welcome to the forums.
It is generally accepted that you can do mufflers without any problems.
The mufflers will never allow enough airflow , because of the air filter restriction of the stock AC.
Once you open up the air filter , you can then produce enough flow that the ECM can't "quite" compensate fully for the increase.
If you were a fairly conservative rider , you might be OK anyway , but a tuner would be the best way to compensate "properly" for further mods.
Mick
Mick
NETacomaFatboy
05-16-2013 12:53 PM
MikeSz
10-26-2010 07:28 AM
