Help with Primary Fluid
Hey Guys,
I have a 2008 1200 custom.
I'm baffled, I'm leaking Primary fluid from the inspection plate cover. Here's what I've done.
1) I replaced the rubber gasket.
2) I replaced the bolts along with new o rings
3) I put another new rubber gasket I
4) then I doubled the gaskets, and this worked for about two days and it's still leaking.
Any feedback will be appreciated, thanks in advance.
The Primary Chain Inspection Cover was changed around '08. It's my understanding that the new gaskets, formed to fit the revised cover, does not work with the old covers. You may need to buy the newer version of the inspection cover (probably 20 bucks), if the gasket hasn't been replaced in a while. If someone has a pic of the back of their '09 up cover, you might be able to compare it to your existing. The old gasket went obsolete years ago.
did u clean and dry all surfaces ?
what type of gasket was removed before installing the new one ?
was it the same one or did they give u a differ style / material ?
do u have the old gasket ? use that one , i bet it wont leak
if not get a new cover and gasket
exact as what harley scuba said above
