Not to hi-jack this thread but, your front bag where you get it? I like that it looks like it holds its shape over the yrs mine has collapsed a bit.
Got it at "The Motorcycle Outpost" in Westminster TX. Its basically
one of those made in Thailand(or Pakistan) types. Its not leather.
It uses heavy duty velcro to keep the flap closed. Cheap, but
does the job (and the wife likes it ) I'd say to try to find a
motorcycle specialty store that deals in leather jackets/chaps/etc
good luck,
T.
Reason: spelling
Agreed - here's what the Custom Dynamics w/smoke lens looks like.
(old pic of wife's Iron)
and with AutoGem glass lens
hope this helps,
T.
Which led set up are these? I want them for my tail lights but want red lenses. Also what front brake rotors are those and where did you get them? They look like the EBC rotors but couldn't find black centers. If they are EBC are they narrow or wide band?
These are Roland Sands Design Tracker signals here. They are much brighter than stock and only about 1/3 of the size. They are 3 wire design so the work well with my 883's Run/Turn/Stop module. I am using the Badlands LE-03 hardwire load equalizer.
Custom Dynamics. You can use theirs with the stock red lens.
(I'm assuming you have an Iron as well).
Yes the rotors are EBC Contour rotors FSD0006CBLK narrow band,
black centers. I got them off of Amazon. Be careful if you try
to get a matching (10 button) rear rotor RSD018CBLK. I ordered
the RSD018CBLK 3 different times and received a front rotor FSD0005CBLK. Had to go to Ebay for the rear rotor...
(RSD018CBLK is a wide band rotor since I still have the stock rear caliper)
