Stator Question.,,
Stator Question.,,
A friend of mine has a '06 1200 Sporty. He want's to ride thru the winter, so he bought some heated gear. The problem is, the gear works fine as long as the rpm's are over 2k, below that his dash lights come on, and the rpms get real low. My thought is the draw exceeds the output of the stator. Now, does Harley or anyone make a higher output stator? Or is adapting one from another model bike doable?.,,,
Cycle Electric makes a 32 amp, 3 phase, system that will replace the stock 20 amp system on that bike. It includes a new stator, rotor and regulator. The 3 phase systems are much better at producing power at lower RPMs, as well as having more amps.
Running a heated jacket/vest and heated gloves works fine with the stock system. I assume your friend bought everything in the catalog, including heated underwear...........
You can't just pump 32 amps from the 07up stator into a regulator that only designed to handle 22 amps, you would have to replace the entire charging system which is what the Cycle Electric system does, and with better quality parts. The 3 phase CE system also solves the lack out output at low RPM's.
Joking aside, this is really easy to work out. All you need is a multimeter to check amp draw and voltage drop on the bike, while all that lot is switched on. You could then disconnect some of them until you have a set-up that works.
I have never come across anyone who uses that combination of heated gear! Where the heck is he planning to ride?
