DK CUSTOMS THunder Torque Inserts - w/ V&H 3" Slips
So I've tried searching the forums and trying to see if anyone has used this combo - so far only found them used with Thunder Header ones (and modifications had to be made).
Has Anyone used the DK Customs Thunder Torque Inserts with Vance & Hines SLip Ons? Did you have to drill a bigger hole or did it just replace the existing bolt that holds the baffle in place?
Thanks in advance!
Thanks in advance!
DK has posted before the V&H require the hole to be enlarged. I have the same pipes and used http://www.smartpartz.com/ to quite the cruising decibel down. Let us know how the DK's sound when you get them instaled.
Thanks in advance!
Thanks in advance!
As others have stated, the hole in the Vance and Hines exhaust is a little smaller than our 5/16 stud. You can either drill that out a bit, or just drill a new hole in the slip-on for then thunder torque insert to go.
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
