Transmission mystery
ok,
I took the cover off, remoed, the spring, the nut and other nut to take the clutch pack off. Everythign looked ok to me. I could "twist" the clutch and watch the ***** in thier ramps and see how it seperated the 2 halves of the clutch. Then put it all back together
When in Netural, all sounds fine ( clutch handle pulled in or not ).
When in first with the clutch handle pulled in, the noise is audible.
As the handle is released, the noise gets louder. There is minimal to no power getting to the wheels, and there is a burning smell.
Is it possible I unscrewed the adjsutment screw too much when talking the cluctch off to take the cable off?
I really can't see what it could be.
I think he's talking about the ball and ramp when he says the 2 halves of the clutch separated. Just using the incorrect terminology, which makes diagnosis much difficult. I think the "nut and the other nut" are the locking nut and the nut on the adjusting screw?? I have no idea what is meant by the "clutch pack" is except maybe the entire ball/ramp assembly?
Did he even have to remove the primary cover to change the cable?
John
John
That seems likely, since that's about the only thing that interacts with the clutch itself. Good luck, try to start over with setting the screw, and go from there. The screw moves outward when you pull the clutch lever, if that helps you orient yourself to what direction you need to adjust.
John
