Touring shock question
Installed a set of V-Factor Chrome 12" Low Profile Heavy Duty Air Shocks tonight.
Running independent valves pumped up to 15 lbs.
Had to add washers inside top mount to get clearance . Left side bottom bolt required shimming to get clearance from the caliper. Shock boot was making slight contact.
Took it for a quick 5 mile ride, and so far a major improvement over the stock shocks.
Amazon.com: V-Factor Chrome 12" Low Profile Heavy Duty Air Shocks for 1997 and Newer Harley-Davidson Touring models - 29023: Automotive
Picked them up from Craigslist NIB for $100.Running independent valves pumped up to 15 lbs.
Even on the little Sporty there is a pressure difference.
Leave the zero loss pump hooked up to the right shock while on the side stand. Stand the bike straight up and watch the gauge pressure on the pump increase.
My metrics recommend checking pressure on a lift to get equal pressure, and to prevent loss of shock oil.
In the air.
Same principal as a servicing a Boeing aircraft strut while on jacks.
We can only give the strut a precharge while the aircraft is lifted.
All shocks are connected at two points not just one, so more then the swingarm is involved.
There is a 2-3 lbs pounds difference on my 2014 Sportster right shock between leaning then standing.
