re-jetting a 06 xlr
Old 12-24-2014, 08:31 PM
1maddmaxx's Avatar
1maddmaxx
1maddmaxx is offline
Default re-jetting a 06 xlr
Ho, Ho, Ho, Y'all
Merry Christmas. I am needing some info on re-jetting my stock carb. I want to remove my baffles and install a Big Sucker air cleaner. Not familiar with jet sizes. Any info would be greatly appreciated.
Old 12-24-2014, 09:39 PM
Mick's Avatar
Mick
Mick is offline
If you don't mind digging right in , the first thing to do is pull the carb , clean it out really well , remove the base mixture plug and ID the jets.
Usually the stock jets are #42 pilot and #175 main.
If you want to make a couple changes that will get you close , grab a #44 or #45 pilot and a #27094-88 (1988 sportster) needle.
Make sure to have a factory manual at the ready and set the float properly.
The main jet size is very close to proper if you don't do some crazy build.
For under $20.00 , you will be very close to perfect with this combo , and will get great fuel mileage.
The #44 pilot can be had used from an Electra Glide if you have any friends that re jetted their twin cam.
The needle may be in stock at the dealer , mine was when I did a couple bikes for friends.
Set the base screw mixture at the proper base RPM hot and you should have a nice running bike.
Mick
2006FLST
EVO
12-27-2015 04:58 PM
Jasber
06-25-2015 06:31 PM
MGN54
09-17-2012 09:01 AM
2002fxdp
05-16-2007 11:03 PM
HDF Tech
Carburetor Related
03-19-2006 10:08 PM
Quick Reply: re-jetting a 06 xlr
