CV Carb Issue pls Help
I have browsed through many of the carb related posts and not found what I need. I have finished an 89 rebuild project and now have carb issues. After completing the rebuild the bike started great, idled with choke when cold and idled unassisted when warm. I had the bike running great took it on some shake downs found a few bugs and worked them out.
Now the problem, the bike will not run over 40 mph for any distance over a 1 mile or so. I can cruise at 30 or right at 40 no sweat, but over that it gets fuel starved and dies. I pull to the side sit a second or two, cranks right over and off I go. It get fuel starved any time I go over 40 mph for some reason.
What I have done:
I have changed fuel out from old for new. I have used 90+ octane and 87. I have clean tank and cleaned in-tank filter ( which was partially clogged). I have a new petcock on tank, I have an in-line filter (clear) so I can see it is fuel starved when it, dies as there is no fuel visible in filter. I have removed the in-line and ran straight hose from tank to carb, with no change to operation. I even read a few posts which said to clean the carb. So.....I pulled carb and took it apart clean with carb cleaner all ports, tubes and jets. Blew it out let it dry and put it back together.
What I got:
After the carb cleaning, I started the bike up. I immediately noticed and a hard idle and after a couple minutes it just died. Now bike wont start!!!!
I have charged the battery, I am running a Dyna S ignition ( which is working fine), I have fuel in the lines to carb, (replaced the in-line filter). I have spark as the bike does try to start. I have had a couple of carb pop issues earlier but fixed them with a the carb adjustment on idle screw.
I think I have covered all I have done or tried.........Help I wanna ride my bike it been three years in the rebuild I am tired of waiting.
What I have done:
What I got:
What I have done:
What I got:
What I have done:
What I got:
From what you've said the problem is in the line between the tank and the carb.
If the problem is between the carb and the tank it will be easy to diagnose.
Simply remove the fuel line from the carb, turn the petcock on, let it flow for a while, if fuel flows ok, then the problem is not there...
Get rid of the in line filter, they are nothing but trouble.
Replace the fuel hoses.
Okay I found one issue, i put a meter jet in wrong anr fixed it, now the bike starts but I still have the starvation issue when I drive the bike over 40 mph.
I did have to clean the plugs as they were carbon fouled. I am completely stumped, I have looked at the forums and done almost everything they suggested. No vaccum leaks, no air leaks use propane torch to check. The fuel flows from pepcock so it is not blocked. Bike has good acceleration when it runs but any time over 40 mph and it starves out.
If the plugs are fouled, the problem could be a float needle not closing properly, allowing the float bowl to overfill, causing a rich mixture.
Also, make sure the top of the emulsion tube is installed correctly, but usually the symptom of that is the bike wont go above idle.
Did you inspect the diaphragm?
Enginesludge was thinking like me about fuel starvation "to" the carb.
As the bike goes faster , the "demand" for fuel increases to the carb , you say the inline filter is empty when this happens.
This sounds like a "breather" problem of the fuel tank.
When the bike does this starvation thing , loosen the fuel cap and see if the bike speeds up.
If the fuel tank breather is plugged or restricted , the fuel will stop flowing at a certain demand/speed.
Air must be "let in" the tank to allow fuel to exit the tank.
Just a thought.
Mick
Just a thought.
Mick
