Throttle sticking?
Throttle sticking?
Quick summary of events:
I'm new to working on motorcycles, but mechanically minded and have worked on cars for years.
Bought some new grips that were universal, so they used the OEM collars. They were "Posh Gum Grips" for those wondering. After reading some how tos and reviews I went at at. The left side came off easy, quick slit with an exacto knife and loosened the torx screws from the controls and slide the new one on. I will say I had to paint the end of the bars black on the left side because the grips were semi translucent and I needed a dark base to get the color effect I was going for. On the right side was a different story. Very difficult to get the grip off while retaining the OEM plastic collar. Loosened the two torx screws on the controls and went to town on it, took a while but got it done. Covered the new grip inside with hair spray (read this all over the interweb) and place it on the bars. Tightened down the torx all the way on the controls and done.
I noticed today that the throttle is not resetting itself. I turn it and it sticks. Did i do something wrong? So I need to oil anything? I never moved the OEM throttle tube or adjusted the cable. Are the Torx screws supposed to be all the way tight? Can't figure out where I went wrong.
Thanks
Thanks
loosen the throttle lock---- the little star under the housing , maybe its to tight and needs adjusting ?
a simple grip swap shouldnt have changed anything unless u didnt do it correct lol
did u slide the grip all the way up against the throttle housing ?
if you did it wont return - u need to leave a space so it does not touch the housing
the little star bit under the grip
Loosen the torq screws on the throttle housing some. Does the throttle now spring back like it should? If so move the housing around a little while holding it tight by hand (instead of the torx screws) find a spot that the throttle returns as normal (works like it should) and while holding the housing there, tighten the torx screws as normal.
See if the above works for you.
twincambill
06-19-2014 09:13 AM
