Installed: Primo Rivera LED Headlight
Quick question: Did you have any issues adjusting the aim? I installed this too, but I can't seem to get a good a good high beam "spot" to aim on the adjusting line (35" high from 25' away). Not 100% happy w/ the lighting so far...I know it needs adjusting, but my high beam "spot" isn't defined enough to adjust the aim per the service manual. I'd appreciate any suggestions.
Appreciate the quick response! So you're seeing the high beam focused spot at 25'? You know how you're supposed to adjust your headlight against a wall at 25', 35" high? I'm just not seeing that focused football shape 25' away...it's too diffuse. While riding, I can see the football shape, but its not at the right distance...it's almost at the point the low beams should be. The low beams are giving me more light to the side than in front. I'm not sure if I'm doing something wrong, or if the light is defective.
yeah mine seems ok. I basically marked out the 25' in the driveway, put a board down and brought the front tire to it. Then I used paint tape on the white door to make my adjustments. Wish it wasn't so cold so I could do pics. I think I'd give Primo Rivera a call and see what they think.
Put it on low beam and the part closest to you will have a very distinct "line" where the light ends. What you do is adjust the light position until that line blurs a tad. Then when you snap on the high beam it should at a perfect distance. This got me the most out of my light. I just wish the darn low and high beam stayed on when you turn on the high beam. This would be ideal. The current version of the Daymaker does this.
Note - as I mentioned in my original post, for true night riding and to be safe you'll still need good, auxillary driving lights. Like the Denali D2. They're just so damn expensive.
Hope this helps
I adjusted mine this way:
Hope this helps
Hope this helps
Thanks for the tip, I'll give that a try.
I agree with you, I wish the low & high beam stayed in high beam mode, but $400 bucks for the Daymaker, plus $60 for the required shell/insert to make it fit the 06 Street Bob was just too much for me.
