2013 Iron 883 to NRHS 1250 KIT Power vision
So i know there are many people with probably the same iron 883 with all of the same modifications.
2013 iron 883
Vance and hines short shots
After market air cleaner an so on.
So i did the NRHS 1250 kit with no headwork did myself, pretty simple installation.
Installed the Andrews N4 Cams.
Upgraded Clutch Spring.
Dynojet Power vision.
I emailed dyno jet for a tune for these specific upgrades, but they only send a Base make for a 1250. I don't understand why they wouldn't have a tune ready that has been dyno tuned and ready for someone to just upload it to their powervision.
So then i emailed NRHS because its their kit and so many people with the same bike as mine wanted more power. I would think they get plenty of emails for maps with the same upgrades.
when i first emailed them i did not have the cams installed and dan from nrhs emailed quickly an said they did not have a tune for just the 1250 kit without cam upgrades but had one with the andrews n4 cams, so i think he just sent a base map.
so a couple weeks later I upgraded the cams because we were emailing back and forth and was convinced to buy the cams and emailed him again, did not receive a email for 2 days for i tried again. He then sent a map an up loaded it to the power vision an i was getting crappy gas milages an my engine was running really hot.
I then checked the map information and it was for XL1200 With Thunder Header 2into1. I emailed him to see if it was a mistake but i haven't received a response.
So i decided to just switch back to the base 1250 map. i really don't want to spend all the money to get it dyno tuned.
Theres gotta be someone out there that has a map for me.
Help me out...
Side question:
(when i have the clutch pulled in in first gear and i just roll on the throttle quickly there is a pause for a second and then it revs, sometimes it will pause then rev with a loud *** pop.) whats up with that??
2013 iron 883
Help me out...
Side question:
Then IMHO you are not finishing the job off properly! All that effort and cost invested and you are prepared to spoil the ship for a cents worth of tar. What is it about a dyno tune that you don't like?! Let us help you understand and help.....
I don't understand not liking the dyno - it's your friend, enabling a tuner to adjust your bike throughout the rev range and optimise it's performance! Done it twice on my Glide, with excellent results. You really should get it done as soon as you have some initial break-in miles on it, then leave well alone until you have your heads done. Makes no sense to put it off.
I believe I have a couple of base 1250 maps that hammer sent me when I did my conversion. They aren't spot on but will get you close enough to basic tune with your powervision. This is what I did until I got head work & cams done. Just pm me with an email address & I'll try to get them out sunday
Received 3,939 Likes
One of the benefits of getting a Power Vision from us is free lifetime "Maps/Tunes".
Even if you got it elsewhere, email us at Support@DKCustomProducts.com and put my name (Kevin) in the subject line. We will get a good base tune for your set-up emailed out to you.
You can then use that to do some "auto-tuning".
Doesn't the PV have an auto tune feature. There are too many variables to a map. Exhaust, air filter, head work cams, etc. you are asking a lot to find a map that is the exact same as your setup. I would get a dyno done if I invested that much money. Usually if you need to get an update on the dyno a year or so later they charge you a lot less.
His set-up with the-
NRHS 1250 conversion
Andrews N4 Cams
Short Shots
Outlaw 587 A/C
is a fairly popular configuration. Getting a good base map/tune for it is not a problem. Then using the "autotune" feature to get it dialed in to his riding style and conditions is as easy as pushing a few buttons on the touchscreen and riding.
