Do I really have to do a stage 1 flash/eXID
Hi,
2009 Sporty with Screaming Eagle slip ons and a free flowing air intake (RamFlow); that's about the only tweaks.
The bike has the O2 Sensors per the factory, so other than running slightly lean why would I need to do a dealership stage 1 flash etc if the bike is running fine (have run Harley's for 20 years so not new to them).
Am new to my Sporty and EFI though so a genuine question.
Great question. I did download on 2012 1200 but often wondered what I bought. Been told by some that it didn't change AFR. Mainly increased revs. Evidently there's some sort of rev limiter with stock mapping. It does rev out higher and more range through gears. Seems to have better power band. But biggest gain in performance was due to SE Slip Ons.
So I was just reading this from the Nightrider site that helps cut through some of the myth that seems to be floating around.
http://www.nightrider.com/parts/ied_faq.htm
Interesting read....
Received 3,939 Likes
Factory target AFR in closed loop is 14.6:1. The o2 sensors work to keep that AFR at that 14.6:1, regardless of temps, humidity, elevation, worn parts, dirty air filter, etc. That is what they are designed for, and they do a pretty good job at it. And even if they do their job and keep the AFR at 14.6 or 14.7, that is the best AFR for a complete burn and the least air pollution, but it is not the best AFR for performance.
But when a free flowing air filter and free flowing exhaust is added, it changes the AFR so much, that the o2 sensors can't get a read to even send a coherent signal back to the ECM to make the adjustments needed. The stock narrowband o2 sensors just can't handle that much change.
Tanuki
Engine Mechanical Topics
10-26-2012 09:48 AM
