Need Help! Removing Slip-ons with crossover pipe
Okay, I read several threads and did research on how to remove slip-on and it seems pretty easy. But the information did not mention removal or disconnecting the crossover pipes. My Sportster has crossover pipes connected to the slip-ons. (not the header pipes).
Will the exhaust move that much away from the crossover connection (I say need about 1" to the side) that it will slide out?
Any help is very much appreciated. I will be getting my 3" Bassani slip ons tomorrow and just preparing to remove the existing slip-ons.
Loosen both flanges up, and you'll be able to wiggle the slip-ons back on to the crossover.
Then bolt on the slip-ons, re-torque the header flanges, and finally tighten the muffler clamps. In that order.
Word of advice... Some penetrating lube may help with removal of the old mufflers. One came off quite easily for me. The other was a bitch, requiring much effort.
Oh! One final thing... Most recommend replacing the crossover "crush sleeves or crush washers" or whatever the hell they're called. Two of them. One for each muffler.
Also, new muffler clamps is also recommended. I did both. The crush washers were included with my muffs. The clamps you'll likely have to source from Hardley.
Thank you for the advice. Unfamiliar with terminology, the flange that you are referring to are the ones for the cylinder...where are these flanges?
Another question - in a review of the Bassani slip-ons, someone said it does not have a crossover connection. I this normal for aftermarket slip-ons? Can you run the exhaust without the crossover pipes?
The flange is what 'holds' the header pipe to the head of the engine. Two bolts hold each on. On the engine itself... Those four bolts will need to be loosened.
And those pipes don't have a crossover inlet? Not sure what to say, other than you don't need them. If they still fit, I guess all is good. Be prepared for a loss of low end torque without utilizing the crossover though...
I was told 99% of aftermarket slip ons do not have crossover ports. I learned that crossover balancing tube is part of the mounting bracket for the slip-ons so does not appear to be removable.
If you installed aftermarket slip-ons on your sporty, what did you do with the crossover tube that is no longer being used? Did anyone remove it (i.e. cut it off) or just plugged the ends...and if so, with what?
CORRECTION: The vendor that told me 99% of aftermarket slip-ons do not have crossovers, retracted his statement and indicated MOST do have crossovers.
