Iron 883 oil question
I and many others have run Rotella in motorcycles for years. I have over 50,000 miles on a Kawasaki 1600 running the stuff in Texas heat.
This is my first Harley and I am trying to learn and do it right. Thank you
I bought the Castrol 20/50 oil that you recommended. $6 a quart. I also found a trick on here I think DK customs said about getting the filter off. He used tin foil to shove in there and create a little drain. It worked perfectly because you can mold it to what you want.
Thanks for the help every one
Cool. Save the tin foil for the 1000 oil change. By then you can probably go with the Synthetic 15W-50 Mobil that Scuba showed you above.
http://www.walmart.com/ip/Mobil-1-15...5-qt./20713647
Ride Safe - Ride Smart
"He Who Lives In Joy Does His Creator's Will".
The Baal Shem Tov, Founder of Chasidic Judaism... ca. 1750's
I'll tell you this... In Canada, a lot of our vehicles are the same as your vehicles, Hardley included. For some reason, you guys are hooked on synthetic, with many manufactures spec'ing only that. The same vehicles here are spec'd with Dino. Ford, Harley, etc.
I can't figure this out, since up North, it's really cold, and cold starts are tough on an engine.
The only thing I can figure, is that synthetic oil potentially has a longer lifespan in use, with additives and whatnot, but with the 3,000 mile oil change myth still alive and well, I don't see people extending their intervals either. Not here, nor there.
