2004 1200C sportster starting trouble
a friend has a 2004 1200 c fully charged bat put it in and it will try to turn over slow then just click. put a volt ohm meter on it and the bat drops to 6 V I think it is the starter he thinks it is the bat could it be both? thnx learning harley as i go
Received 4,614 Likes
Poor ground (usually corrosion, or just loose) can cause that clicking, but the battery shouldn't stay below 12V after trying it. After trying to start it a couple times, if the battery is below 12V but charges back up in a few seconds on a charger, only to repeat when you put a load on it, that would likely be a shorted cell, have to replace the battery.
