building a seat for the 48
to be honest, when I took it off, I never thought I would use it again since it sucked so bad, so I sold it.
I did like the look of the stock seat so a couple of weeks ago I thought about looking for a similar looking seat that was more comfortable and I thought of this project. realistically, I cant see the sporty 8 being much more comfortable than stock so I figured i'd try and add the gel and see what happens.
if this don't work, i'll try the lapera bare bones even though its a little bulkier than i'm looking for. I had one on my fatboy and it was fine, I rode from NY to Laconia and my *** was fine.
I like the look of the stock seat too. I paid someone to make me a foam cover to make it more comfy. The problem was it's easy to slide off it when you are accelerating. No seat grabs my rear better than this mustang seat I put on. It's much safer as well as comfortable.
ok, so the seats at the shop. were going to cut out the middle of the seat to fit the gell pad in to perfectly line up with the original height, at the red line in the picture, were going to make that area a little deeper by shaving the original foam so we can have a bit of a rear lip, so not to slide back so easily on takeoff. i'm going to have a 1/4" felt piece and a dacron foam cutout to go over the gell area on top, to keep the heat off my *** from the gell in the summer, then finish it with a distressed black leather cover.
now here's my question....the pan is made of a hard plastic, so my friend said he would have to glue the pad to the pan. that doesn't sound to permanent to me, i'd hate to have the seat rip off the pan when i'm on the highway. he doesn't want to drill or put tacks for fear of the plastic pan cracking. does this sound right? ive emailed and called biltwell this week but have heard back from them.
won't come apart.
I did some reconstruction on my seat and I went to HDepot. Go some short screws in those little baggies and some furniture washers in those little baggies and pulled it tight and screwed it into the plastic pan. Didn't break and I might have used to many but ,,,,,,,,,,,
Note: seat was already cracked from PO. It had staples in it and they were a pain to get out, rusted.
He will have to drill holes for rivets or screws on the cover pretty common with no problems.
