Ape Hangers on a sportster 72
Old 03-05-2015, 08:46 PM
Chamby's Avatar
Chamby
Chamby is offline
6th Gear
Default Ape Hangers on a sportster 72
Hey guys I know this info is probably on here somwhere, but I can't seem to be able to find it. I've searched and searched and can't seem to come across it!
So here goes I have a sportster 72 and I'm looking changing the bars, I'm thinking of going with the burly narrow 14" apes, my question is do I need to get longer cables and brake line or is there enough slack for the 14" bars Im thinking I will need to lengthen the wires but not sure if the cables and brake line are long enough? I'm trying to avoid having all that extra cable just hanging out there? Any insight would be appreciated!
Old 03-06-2015, 11:01 AM
willg's Avatar
willg
willg is offline
If you want to put 14" apes on, I believe you need extended cables. I think you can make it work with 12" apes. check xlforum there is a post on this topic
Old 03-06-2015, 06:15 PM
NightsterNick08's Avatar
NightsterNick08
NightsterNick08 is offline
5th Gear
When you go thru the Burly site and select your bike they suggest you get the extenders. Well it's more then a suggestion.
I opted for Roland Sands at similar height and it was a perfect marriage from the previous apes on my Nightster
Old 03-07-2015, 07:52 AM
gdishman's Avatar
gdishman
gdishman is offline
If you put on the 14 inch apes then use the burly 12inch cable kit. There cable kits are long. The 12inch cable kit kits perfect.
Old 03-07-2015, 08:40 AM
nashvegasmatt's Avatar
nashvegasmatt
nashvegasmatt is offline
Ditto.. The cable kits are waaaay too long. I put on 12" bars and have only used the longer clutch cable...kept factory for the rest...
Old 03-08-2015, 09:10 PM
Chamby's Avatar
Chamby
Chamby is offline
6th Gear
Thanks for the info guys!
Old 03-09-2015, 02:39 AM
xknucksx's Avatar
xknucksx
xknucksx is offline
I installed a set of 16" narrowglide licks apes on my buds 72 and the only thing i extended were the throttle cables. Rerouted the stock brake and clutch cables and the wires had enough slack.
clayman
09-20-2014 04:07 PM
McMuffin
09-03-2014 01:11 PM
rgm
01-14-2013 05:09 PM
Nightster Ridester
02-08-2010 06:36 PM
bigdaddyhill71
09-11-2007 12:02 AM
Quick Reply: Ape Hangers on a sportster 72
