89 883 project, need HELP!!!
Old 03-18-2015, 12:22 PM
DieselJoe's Avatar
DieselJoe
DieselJoe is offline
Default 89 883 project, need HELP!!!
So last night I picked up an 89 883 with under 10k miles off craigslist cheap, guy said it needed work but starts. When he started it last night there was gas coming out of the intake side of the carburetor while cranking, back fired through the carb a couple times, then started on 1 cylinder... I figured it probably needed a carb cleaning no big deal...
So this morning as I'm working on it I noticed both the cylinders look fresh, not "weather worn" like the rest of the surfaces of the motor.... So I clean the carb, put it back together and it's doing the same thing, gas comes out of the intake side of the carb while cranking, back fires, starts on one cylinder, I was able to rev it up and get both cylinders firing but it didn't stay that way for long...
Anyway I'm starting to think it's a timing issue, what do you guys think???? Would really like to get this thing going so I have something to put around on until my bagger is finished...
Old 03-18-2015, 12:56 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
could be a burned valve (not too likely) .. but my money is on the timing being screwed up, I would pull the timing (points)cover off and give the inside a good look see, I have seen a good amount of the older bikes have water damage in there...or someone might have screwed up the cam install..I have read about folks taking the cam cover off to polish it not realizing that the cams will come out with it....
Old 03-18-2015, 12:57 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
oh, and check for water in the gas...
Old 03-18-2015, 01:14 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
I'd do a compression test first, it sounds like you might be getting compression pressure leaking backwards through the intake.
Old 03-18-2015, 01:42 PM
DieselJoe's Avatar
DieselJoe
Any videos or write ups on how to check timing on these motors? Looks like my timing cover is riveted on.....?
Old 03-18-2015, 02:39 PM
DieselJoe's Avatar
DieselJoe
Here is a video I took with my iPhone, seems to run fine at a decently high rpm can you can see, but if I let it drop below a certin point it will sputter and back fire through the carb
Old 03-18-2015, 04:57 PM
old schooler's Avatar
old schooler
old schooler is offline
Did you put a new set of plugs in?
Old 03-18-2015, 06:40 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
Here is what I would do:
Confirm you have a strong spark going to 2 good spark plugs
Pull the tank and petcock. Wash out the tank and clean the petcock screen
Fresh fuel
Complete carburetor rebuild vs. cleaning
Replace both manifold intake gaskets (between the heads and intake manifold)
Rivets are in place at timer cover, so likely not a timing problem
Old 03-18-2015, 07:02 PM
mad jak's Avatar
mad jak
mad jak is offline
change ur plug wires to eliminate the easy stuff check plug gap also
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Clean the carb
dont panic
Quick Reply: 89 883 project, need HELP!!!
