Oil filter change mess
Old 04-22-2007, 01:56 PM
John3:16's Avatar
John3:16
John3:16 is offline
Default Oil filter change mess
ok, im stumped, what do you all use to keep from making a mess when you take off the oil filter. As I see it, when I take off the filter, all the oil in the filter in going to run down the side of the motor.
Ive seen a couple of post of one saying punch a hole in the filter and drain it, another said to use a 2 liter bottle, I didnt quite undertand that one tho
Old 04-22-2007, 02:09 PM
AzDon's Avatar
AzDon
AzDon is offline
Default RE: Oil filter change mess
I'm gonna guess that the bottle trick is to cut a plastic bottle and slip it over the filter as you remove it to catch the oil drip. If you can cut the hole only big enough for the filter to enter, the taper might hold the dripped oil. Cut the bottom of the bottle out also, and the resulting tube could be used as a funneland for filter wrench access.I'm gonna try that one!
Old 04-22-2007, 02:10 PM
anubisss's Avatar
anubisss
anubisss is offline
I'm gonna try the 2 liter bottle next time as I made the biggest mess last time...
Old 04-22-2007, 03:14 PM
RICHE's Avatar
RICHE
RICHE is offline
I put a couple of rags under the filter when I remove it.If some drips on the bike I wipe it off.
Old 04-22-2007, 03:25 PM
DeepCobalt 07 street's Avatar
DeepCobalt 07 street is offline
slip a plastic bag over it while un screwing filter.
Old 04-22-2007, 03:39 PM
Nightrider2's Avatar
Nightrider2
Nightrider2 is offline
After you drain the engine, take something like an ice pick, poke a hole on the bottom 6oclock position of the filter, BUT, first put a piece of a plastic milk jug or plastic pop bottle UNDER the filter that is long enough to make to oil flow past the engine cases. Also poke a hole at 12 oclock on the filter[ top of filter] this will help the oil to drain faster. Let it ALL drain, be patient, and you will have VERY LITTLE oil on your bike.
Old 04-22-2007, 10:51 PM
shiyfire's Avatar
shiyfire
shiyfire is offline
I use a piece of cardboard folded into a v shape,slide under filter,place a rag under cardboard where filter base is and remove filter.
Old 04-22-2007, 11:25 PM
jonny ebola's Avatar
jonny ebola
jonny ebola is offline
I did mine this morning with nothing. I always wanted an excuse to buy a spray bottle of degreaser, and i got it.
Old 04-23-2007, 12:04 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
ORIGINAL: Nightrider2
That's exactly my routine, it seems to work the best, at least for me. I don't usually get more than a drop or 2 on the bike.
Now if you really want to make a BIG mess....try changing the oil while the bike is on a motorcycle jack.
[sm=badidea.gif]
Old 04-23-2007, 12:37 PM
bigtop1's Avatar
bigtop1
bigtop1 is offline
A sheet of tin foil formed into the shape you need will do the job as well.
Quick Reply: Oil filter change mess
