Do fatter Front tires last Longer?
But it's also true a bigger tire would create more drag on the road surface.
only real life data will decide.
I have the skinny front and I only get an extra 2-3,000 miles out of the rear and always have the tires changed at different times..
I do still prefer the look of the large skinny wheel though, and the easy steering.
in theory that makes some sense, there is less "Pounds per inch" on the tire surface since the surface area is bigger.
Received 3,931 Likes
I generally get more that twice the mileage out of a front tire as a rear tire...and I use only the front brake for 70+% of my braking.
I've only owned one skinny front tire bike...a Wide Glide...and I did not have it long enough to gauge tire wear.
Since most skinny front tires are 21", most "medium" front tires are 19" and the fatties on the 48, and recently, the Customs are 16", you would think they might even out a bit, since the narrower they are, the larger the circumference to handle heat and wear. (all else being equal...rubber compound etc.)
I am on my first fatty ever, so do not have enough experience to back up any particular theory though.
I do know this for a fact...if you make sure you do a lot of riding in the curves...both the front and the rear will last longer...you're using all the tread, not just down the center.
My bike came with the skinny 21" front wheel. The first 2 front tire changes came at ~7500 miles on each tire.
After the second 21" tire wore out, I swapped to a 19" wheel with the fatter 100 tire. Every front tire since then, for the next 85,000 miles, has lasted over 20,000 miles each.
