How to I adjust forward control linkage?
Hi peeps, I've just fitted some drag specialites forward controls to my sportster iron but can't work out how to adjust the rod to get gear selector at the right angle/position. The instructions say to adjust the link bar that goes from the selector pedal to the gear change arm however when I loosen the 13mm nuts at each end of the rod and turn it it just spins to the left or right but doesn't seem to move anything? It just freely spins on the threads of the little ball joint bits on the end which then attach to the pedal and gear arm. Am I missing something???
Cheers
Cheers
