2000 sportster oil change
Any tips on changing the Trans oil? lessons learned... Don't dos...?
Just food for thought.
here are a few discussions... as you'll see, there's a debate amongst everyone and they all know better than the other.
http://www.harley-davidsonforums.com...synthetic.html
http://easyrider.easyrider.com/syn3.htm
http://www.cvoharley.com/smf/index.php?topic=7277.0
So there - read up and make your decision based on the information. I have mobil1 just like the first responder posted... mostly because I think the Syn3 is overpriced and not as high of quality (you're paying for the name)... but to each his own. Some swear by it.
Hows that for a non-answer! HAHA
Hey, another oil thread!
Ok, I'll chime in. Sounds like you are new to HD and bikes in general. I am relatively new myself.
I've changed my own oil and had the dealer do it. My recommendation? Why not use whatever HD recommends for your year bike until you have a good reason to change to something else? I run Syn 3 in my 2011 1200C. If that is also recommended for your 2000, use that in both (again, if recommended for your 2000) holes.''
I have a 2007. Went to the HD Dealership and asked for a quart of Synthetic Primary fluid , as I want to switch to a Synthetic Oil in the case, and they recommended and sold me a quart of 20/50 Screamin Eagal to use.......I see you have 75/90.....am I ok with what I put in my Primary?
yes, you will be fine...20w50w is almost the same as 75/90 gear oil...motor oil and gear oil are graded on different scales so the numbers are different...
