2013 1200C Speedometer oscillating dealer can't figure out
Old 04-26-2015, 06:39 PM
dgretz's Avatar
dgretz
dgretz is offline
Default 2013 1200C Speedometer oscillating dealer can't figure out
Have had the bike into the dealer 4 times now.
Replaced
VSS 2times
new speedo
new ECU
new connector pins on wiring harness connector to speedo, and traced wiring.
Still have oscillating speedo needle
Any other suggestions???
Old 04-26-2015, 07:14 PM
Johhny51273's Avatar
Johhny51273
Johhny51273 is offline
The only time I had any issues with my speedo it was "pulsing" when I had a loose ground to the battery. Just in case you haven't checked your battery connections yet.
Old 04-26-2015, 10:44 PM
BikesFixCobwebBrain's Avatar
BikesFixCobwebBrain
BikesFixCobwebBrain is offline
6th Gear
Saw the same Speedo prob on a softail that had a bad battery in it.
Old 04-27-2015, 05:55 PM
Mick's Avatar
Mick
Mick is offline
Check the headlight and see if it pulses about the same interval as the speedo would at the same rpms.
Just hold the rpm and look at a bright wall , you may have a regulator that's switching instead of being smooth.
Definitely check the grounds and if the battery is more than 3 years old , suspect it.
Check the running voltage with an analog voltmeter (not digital) and watch the needle for the pulse.
Just a couple thoughts.
Mick
supermanotorious
01-25-2019 04:30 PM
Boris1642
03-27-2015 11:28 AM
Robert Strohl
07-15-2014 05:49 PM
Williams HK-WS
06-23-2010 10:41 PM
wayfat
03-19-2006 12:00 PM
Quick Reply: 2013 1200C Speedometer oscillating dealer can't figure out
