Best way to lift the bike without a jack?
Old 05-04-2015, 07:59 PM
Bowhunter8607's Avatar
Bowhunter8607
Bowhunter8607 is offline
Default Best way to lift the bike without a jack?
I need to lift the rear of the bike to swap out the shocks but I don't have a jack. Any suggestions on how to go about this?
Old 05-04-2015, 08:01 PM
davidwruth's Avatar
davidwruth
davidwruth is offline
Lift it by hand and put a log under it
Old 05-04-2015, 08:50 PM
SLV's Avatar
SLV
SLV is offline
It's true. A stock of lumber works too. If necessary, rock it back and forth while shimming under one side and then the other. As long as you change one shock at a time, you don't have to raise it much.
Old 05-04-2015, 08:59 PM
cripple's Avatar
cripple
cripple is offline
I built a jack out of 2 pieces of 2x8 glued and screwed together and then drill a hole and insert a metal pipe as a lever.
Old 05-04-2015, 09:27 PM
davidwruth's Avatar
davidwruth
We had to balance a guy's tire on a trip and this is how we did it
Old 05-04-2015, 09:46 PM
Copytech's Avatar
Copytech
Copytech is offline
A pic of wat Cripple is talking about.
Old 05-04-2015, 09:47 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
Use the scissor or bottle jack from your car with a piece of wood.
Old 05-04-2015, 10:23 PM
starforbrian's Avatar
starforbrian
starforbrian is offline
Honestly, I would just go to Harbor Freight and buy a jack. It isn't necessary and many people come up with clever ideas or simply use a car jack, but when the time comes to really work on your bike you'll be grateful for the jack. I picked up their blue aluminum one for $150 or something; they have a cheaper one that recently went on sale. Don't forget to check their flyers for coupons.
Old 05-04-2015, 11:13 PM
Bowhunter8607
Yeah that same blue jack they have at the harbor freight here is 289 plus tax So I haven't had the money to pick one up. Nonetheless, I got it up and progressives installed. Now to feel the difference on my way to work in the morning!. Thanks for the ideas guys!
Old 05-05-2015, 10:36 AM
tvon's Avatar
tvon
tvon is offline
Also note, if you are raising/lowering your shocks, a proper jack will make this job way easier. Watch some of the tutorials on youtube (J&P cycles one for instance) and you just pump the jack to the height of the new shock.
Quick Reply: Best way to lift the bike without a jack?
