08 883 low wont start
Old 05-09-2015, 03:19 PM
SuperG96's Avatar
SuperG96
SuperG96 is offline
Default 08 883 low wont start
So today i picked up an 08 883 that has sat in a guys garage for 2 years never started. Im sure the battery is junk but i was hoping just to get it to start after i flushed the tank and mixed the new gas with seafoam. It will click really fast and sometimes it will turn over but not start. Lights are bright and seem to have enough juice to start it with the battery charger but it just cranks or clicks. Can i give it a shot of ether or no? Where should i go, cant pick up the battery until tommorow, like to atleast get it running tonight.
Old 05-09-2015, 03:24 PM
SuperG96's Avatar
SuperG96
SuperG96 is offline
Also if you crank it too long all the lights and everything go out and you have to wait a minute before you try to turn the key on again
Old 05-09-2015, 04:01 PM
SuperG96's Avatar
SuperG96
SuperG96 is offline
Pump was making sounds now its not?
Old 05-09-2015, 05:19 PM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
Get a new battery before you keep messing with it. If the battery is toast, even if you get it started it wont run very long. Depending on what charger you are using, you may just cause damage to the electronics.
Old 05-09-2015, 05:22 PM
SuperG96's Avatar
SuperG96
SuperG96 is offline
Thats what im gonna do, it was just clicking , pulled the plugs and no spark but the motor will turn over fine as long as the plugs are out.
Old 05-09-2015, 05:23 PM
SuperG96's Avatar
SuperG96
SuperG96 is offline
No spark and no fuel on the plugs
Prewoz
06-10-2017 05:25 PM
mchganfan
05-18-2016 12:14 PM
sfad
05-04-2014 10:36 AM
intense883
02-22-2013 05:10 PM
feistycadavers
08-16-2011 08:24 PM
Quick Reply: 08 883 low wont start
