Sportster question
Got to ride before the rain started again on Monday. 101 miles and only one time did the bike hiccup (no smoke, no bike fire, just an ever so brief power change) while I was accelerating on a slight incline. We had gone about 40 miles. Also checked with Harley dealership in Tulsa yesterday and found out the pn # my diagnostics gives is not relevant since there is not error code. Service guy says "it's the ECM #"? Soooo. I do hope to get to look over all electrical in next few days. Then will start with troubleshooting according to service manual that i now have.
This is a symptom of the petcock I mentioned earlier, due to low vacuum while accelerating a weak petcock can partially close starving the carb of fuel. Often the first signs of it going are when pulling up a long steep hill or accelerating hard on a shorter hill. The engine is draining the float bowl faster than it's getting filled.
Also a crack in the vacuum line to the carb could be cracked or not sealing well do to age.
Vacuum issue,,,
Received 17,570 Likes
+1 Also, I do know that there is a screen on the petcock that needs clean/serviced. I would ask the mechanic who sold you the tuneup about that. That is equivalent to a fuel filter on a car, which is a tune up item. You can look at the petcock and see if the factory clamps are on it, they are crimp type. If it was taken apart, it should have worm or screw type clamps on the fuel hose.
Did you replace the Crank Position Sensor? Less than 50.00 from the vendors that provide discounts, and seems it was an issue in bikes of that year... It was mentioned earlier - 32804-04A
Easy to change yourself and you can rule it out from the possible causes.
Here is a video link that shows the exact location... easy to swap
