XL883L engine stall randomly
Hi,
In the last couple of month my 2011 XL883L is stalling randomly.
I had 0 luck reproducing the issue and my local dealer did not manage to solve this as well.
In most cases this happens in low RPM and while standing in red light.
I have managed to catch this on video so you can see how my bike dashboard reacts when this happens.
I have tried disconnecting the kickstand sensor to eliminate that option but I still had my engine stalled.
Any idea's?
https://www.youtube.com/watch?v=IiGv...ature=youtu.be
Thanks
Any idea's?
Thanks
We did check the wiring as well did Harley.
I do have a factory service manual as well.
What do you mean exactly by switching the 2 relays?
I experienced same issue before. It was caused by the system relay which could not keep the engagement. Recommend clean all pins and dielectric before plug them back.
It's a good chance that it's the relay as noted before. Make sure that the contacts are clean and add some dielectric grease to the contacts. The relays are known to go bad and leave you stranded at the worst time. I always like to carry a spare along with a spare main fuse as a backup. I ziptie them in the fuse box area for use later if needed down the road. Cheap insurance.
