How long of shocks can I get away with? 5'4"
I've been reading and searching through the forums about shocks. I currently have 11" Progressive 412 shocks on my 2009 Sporty 1200C. I've read that the longer you go with shocks, the cushier the ride can be. I only got the 11" shocks last year when I first bought this bike as they were on the discount table at HD. I should have done more research first.
My issue is that I'm 5'4" and don't want to go too high so that I'm not comfortable on the bike. I have the super reduced reach seat, so that lowers me...so I can afford to go longer some (My feet are flat when sitting). I'm just trying to find that sweet spot of not hurting my back and knees so bad when going over pot hole hell here in Chicago and still being able to touch the ground well. I don't want to tip toe the bike around either when sitting as that kills my knees (3 knee surgeries in the last 2 years on both knees and severe arthritis since). Any suggestions? Should I go 12.5? 13? 13.5? Is there a good way to measure?
Also, any recommendations on a spanner wrench as I want to adjust my current shocks some but can't as they didn't come with a wrench. I don't want to scratch my chrome, so do want a wrench. I saw one on Revzilla that uses a 3/8" ratchet which I'm not certain would work with the 412s? Anyone know?
Thanks
Thanks
Ok....I'm 5'5 ish and have a 28 inseam....and with my Ohlins Shocks can put both feet flat on the ground. They are 11 3/4 in length, just like the stock ones. The ride is awesome and I can cruise the freeways as I please. I would highly suggest looking into some.
http://www.fuelmotousa.com/i-2085954...xl-models.html
Feel free to ask me questions if you need more help.....it did take me while to find the "right" pre-load setting as well. Us lighter guys are more sensitive to getting shocks adjusted properly so we don't get "bucked off" the bike.
Inseam and shocks
I'll need to do more research on the Ohlin shocks. They are about the same price as the Progressive 444s I was looking at. Are they really worth the price hike? I see they are more customized.
I couldn't tell much of a diferrence between the 412s and the 444s from what I've read so far.
My inseam is 28"
My inseam is 28"
Yes inseam is the measurement that matters. Progressives are good shocks. Maybe you should consider changing your seat as longer shocks will cause you to tip-toe if you can plant now. I have 10.5" Burly shocks and fork lowering springs along with mustang tripper fastback 2-up seat in order to plant my feet...and not get back/butt pain.
My inseam is 28"
My inseam is 28"
Yes, I want the Mustang solo seat but that will raise me back up and it's wider than the super reduced reach that I have which also pushes me forward 3 inches. I might be looking at new handlebars too so I have the comfy reach, seat, and foot plant. I was trying to avoid this pricier option but sounds like it's the way to go.
Like you are planning, I actually did a lot to get comfy and perfect on my bike. I now have:
- 1200c handlebars (which have a bit more of a swoop-back)
- 1" handlebar risers
- reduced reach forward controls
- Corbin seat
- Ohlins rear shocks
- Progressive front drop-ins (only cause the 48 has a Terrible stock setup)
Took me a while but I finally found my "perfect storm" you will too!
