Reading plugs
at one time, in the land before fuel injection you would be correct, but even then only when you did the "run test" correctly. With fuel injection and all the setting variables (being able to change the fuel/air ratios all through the power band, along with managing timing changes to cope with these different mix setting), looking at the spark plugs only tells you how the bike was running in a short time before you pulled them, so the bike may be running great with a perfect mix from say, 1000 to 3000 rpms under mid load and running very lean at the same rpms on heavy load, or any of another multitude of variables...Even in the days of carbs the plugs mostly (as far as fuel mix is concerned) only would tell you if you were running rich/ lean across the rpm band, unless of course you did the run test where you installed clean plugs in warm motor started the bike and did a constant run for a set distance and immediately shut the motor off, coasted to a stop and removed the plugs and looked at them...
It's old school but the method still works for me and you just need to factor in that with EFI systems you will have leaner spark plug readings. I will say that I learned how to read plugs from a very respectable tuner when my son raced and without the knowledge I gained from him, I would be a fish out of the water in the fine tuning department.
For your purposes, yes it does. Because once your plugs foul up (for example), no amount of varying setting will "unfoul" them. So if you see that, you know you're running too rich. And maybe too cold as well...
