2003 Sportster 883 "48" - Swap info
Done a little work over the cold season!
Before the winter hit I installed a 1200cc kit to make it a little faster, more desirable and broke it in before it got too cold to ride comfortably.
Chopped the cam cover and pulley cover, then had them powder coated along with the primary cover, rocker covers, rear pulley and air filter. Put a bigger, and matching, rear tire on.
Also, painted it! At school I got to try out a little metal flake, turned out pretty good I think! Lime-Gold Candy, will see how it looks when the bike is all back together.
While having the cam cover off, I decided to install a Dyna 2000i ignition and switch to a single fire system. Now I am just waiting for the rocker covers and air filter to get back from powder coating, bought the single fire coil, and a new seat is on its way.
What do you think so far???
