Clutch line leaks oil
Old 06-24-2015, 02:34 PM
Kevin01Z28's Avatar
Kevin01Z28
Kevin01Z28 is offline
Default Clutch line leaks oil
My clutch line is leaking below the adjuster nut. Dont understand it since it is above the transmission oil level. Any thoughts?
Old 06-24-2015, 02:39 PM
Wayne0's Avatar
Wayne0
Wayne0 is offline
2nd Gear
My vent tube had became plugged, probably by dirt dobbers.
After clearing it out, oil quit traveling up the clutch cable.
The vent is is right on top of the trans and mine had a rubber elbow on it.
Hope this helps.
Old 06-24-2015, 06:42 PM
Iarecobra's Avatar
Iarecobra
Iarecobra is offline
When I changed out my clutch cable, primary fluid leaked out. There is an O ring on the clutch cable. Might need a new one. Also don't over tighten. It's very easy to strip out the case. Then your in another world of hurt. I don't remember the tourqe spec off the top of my head. I just remember I snugged it up just a little past finger tight.
Old 06-24-2015, 09:37 PM
Kevin01Z28's Avatar
Kevin01Z28
Exactly what my problem was Wayne, dirt dobbers had the vent tube stopped completely up. Appreciate the help
Old 06-24-2015, 10:42 PM
Wayne0's Avatar
Wayne0
Wayne0 is offline
2nd Gear
Thumbs up
Kevin, glad to help. Just sharing what had happened to us.
Ride safe and enjoy your bike.
Old 08-12-2015, 02:15 PM
danysoccer8's Avatar
danysoccer8
danysoccer8 is offline
4th Gear
I just noticed my Sportster had the same issue.
Can I just clean it or do I have to replace the clutch cable?
While I'll be working on it and messing with the transfer case, could you guys recommend a Transmission/primary fluid for a '06 XL with 13K miles?
Thanks,
Dan
Charles Bryant
07-20-2018 09:09 PM
GMRO
11-22-2015 10:56 AM
pococj
08-20-2014 05:33 PM
NavyCharles24
03-10-2011 04:22 PM
crewzerdude
04-27-2010 09:18 AM
Quick Reply: Clutch line leaks oil
