beyond XIEDS
Maybe you could run a windows emulation software on your Mac??
https://discussions.apple.com/thread/4097091
Yep, it would have come preloaded with the map for your mods.
I mounted mine behind the left side cover.
Read over the instructions a couple times so you understand everything.
Check and double check all your connections and make sure you zip tie
all wires and connectors away from any heat source.
The one fly-in-the-ointment is this: front female connector housing that plugs into the injector is too large and will not seat down fully. It is interfering with the head. This is a housing with a spring wire that wraps around three sides that snaps into place when fully seated. I can get the connector pushed unto the male connector in the injector, but not far enough to get it to snap into place. Has anyone else had this problem?
I read and re-read the instructions. I mounted mine inside the left cover also. Then I raised the fuel tank and got after connecting the Micro EFI Tuner wiring harness.
