2014 883 Stalling / Missfiring
Old 06-30-2015, 10:59 PM
asianiron's Avatar
asianiron
asianiron is offline
Default 2014 883 Stalling / Missfiring
I have a 2014 Iron 883 with screaming eagle exhaust and DK Custom AC and Xvieds ( something like that) Recently my bike started stalling and misfiring thru my intake.. It idles rough and struggles thru low rpm's thru each gear. i have almost 10,000 miles on bike. Ive changed plugs.. dont know what else it could be... any other sportster owners having same problem? please help.
Old 06-30-2015, 11:48 PM
asianiron's Avatar
asianiron
will the AC and Xievd. cables void my warranty?
Old 07-01-2015, 07:22 AM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
I have never been a fan of any plugin or piggyback systems that trick the ECMs. You are at the mercy of them going bad and creating headaches. I prefer system flash tunes. Looks like you will need to check and see if your Xvieds went bad. Take them off and go back to the original wiring and see if the problem goes away. You should also check the connections and see if you have any corrosion or bad contacts. Don't ride it much because you will be running lean with your setup and that will cause more problems. If it gets better then you know where the problem is. Now you have the choice of getting new Xvieds or getting a flash tune for your setup.
Old 07-01-2015, 08:28 AM
AgentOrange883's Avatar
AgentOrange883
AgentOrange883 is offline
Asianiron-
If it makes you feel any better, my bone stock 900 mile 2014 Iron does the same exact thing upon initial start up when the engine is ice cold. After its been ridden for a while and has some heat in it, it starts beautifully. It literally shoots a puff of black smoke out of the intake, very unnerving.
Old 07-01-2015, 11:33 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
check the intake for air leaks by starting it up and putting a spray tube (the one that comes with the can) on a can of wd-40 or crc power lube and get real close and spray it around where the intake and throttle body meet and where the intake and engine meet, if the engine changes speed when/ or immediately after you spray it you have a leak..if you find no leak, turn off the motor, remove the air cleaner and look inside of the air intake area, if it is dirty looking ( it will be) spray the crap out of it with the crc or wd40, they both have tons of solvents in them that will melt the crud away with doing any damage to the parts, and leave the whole thing nice and lubed..don't forget to put rags under the areas you are spraying to catch the mess...if that doesn't help come back and we can talk some more..
Old 07-01-2015, 12:12 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
Check battery and connections. EFI bikes need a good battery & clean tight connectors to run properly.
Old 07-01-2015, 11:56 PM
asianiron's Avatar
asianiron
will do.. thanks guys!
Old 07-02-2015, 07:40 AM
Traxxtar's Avatar
Traxxtar
Traxxtar is offline
I agree with Cool Inferno, lose the XIEDs and get a proper flash for your ECM. I installed a DK Custom AC and also have a bit of stalling when the engine is cold. With just the AC change, I can tell my bike needs a flash; it doesn't run smooth at all.
Old 07-02-2015, 03:24 PM
Andy Arocho's Avatar
Andy Arocho
Andy Arocho is offline
your best bet is a ECM flash. how soon after the AC installation did this problem start?
Old 07-02-2015, 04:17 PM
jerryw618's Avatar
jerryw618
jerryw618 is offline
Seafoam it.
Quick Reply: 2014 883 Stalling / Missfiring
