Tire buying
Tire buying
I purchased my first bike (a stock 92 Sportster) recently and it is time for some new tires. Aside from buying factory tires/sizes I am completely baffled by what other tire options are possible and/or recommended. I really like the look of a bit larger tire, like the newer sportsters, and the closest obstruction I have on either tire is a good 1/2" away, so I assumed I could just buy the next tire size up. In looking at all the specifics, no tire manufacturer makes their actual tire widths the same width, and as well, my stock Dunlops don't come in one size up.
How would you guys recommend I go about purchasing new tires that work with my existing rims, wont trigger any larger mods, and wont cost me an arm an a leg (financially or literally)?
Thanks!
Thanks!
If you are looking for low-cost tires with decent handling (but not necessarily very long-lasting), the Shinko 777 seems to be a forum favorite:
http://www.motorcycle-superstore.com...7-hd-rear-tire
http://www.motorcycle-superstore.com...-hd-front-tire
HTH.
HTH.
I think the tires you want to buy should match the type of riding you do and how often you want to replace them. There are some tires that will last you 4,000-5,000 miles and others that will last 18,000 miles - depending how you ride, of course. Determine the best tires for the way you ride and that offer the best value (mileage/longevity/price), then look at sizes in that tire that you'd be interested in buying.
I have been on revzilla, Dennis Kirk and motorcycle superstore... And I really have only identified two tires that "might" fit that are bigger than stock size. With my easy driving, either tire would seem to work. Does anyone know how I can verify that these tires will work? Or do I have to buy them and try them since I am going up a width size. Also, do the tires have any flexibility on the rim size they list as compatible? ...some tires list a range of compatible rim sizes while some list a single size...
