Help!!
07-06-2015, 12:50 PM
Help!!
Does anyone have a list of the torque specs for 2015 had 48?? I am needing torque specs for rear axle nut .. And front axle nut pinch bolts ??
07-07-2015, 02:48 PM
Also what is the socket size for the rear axle nut?
07-07-2015, 03:15 PM
From my 2014 manual. Rear nut is torqued 95-105 ft-lbs. Nut is 36mm or that is what I use. Front pinch bolt is torqued 21-27 ft-lbs.
07-07-2015, 04:03 PM
Thank you very much!! What page did you find that on? Or under what in the index?
07-08-2015, 08:34 AM
2014 Factory Service Manual page 2-21.
djdiver157
Wheels/Tires
06-01-2017 12:13 AM
harleyglen
08-04-2013 04:14 PM
glyn fxdwg
07-01-2011 12:01 AM
robertj74
11-20-2009 08:00 PM
roadglide80118
07-28-2007 09:25 PM
