I Goofed....Help! 2004 HD Sportster 1200R
I was changing fluids and when I got to draining the oil from the transmission, I unscrewed the primary chain adjustment bolt instead of the drain plug. Dumb, I know, but what's done is done.
Now the bolt can be turned in both direction with an allen wrench but doesn't move up or down into the cover. The chain is loose at the top travel and actually contacts the cover. I started it very briefly and it's clacking away.
I will likely need to have the bike trailered to my Harley dealer. What I would like to know is has anyone had a similar experience, particularly where the bolt adjustment bolt doesn't move in and out.
Thank you.
Pierre
Thank you.
Pierre
Received 2,189 Likes
Thank you.
Pierre
Thank you.
Pierre
Google the sportster maintenance pdf for your and follow the directions to adjust the chain. It is on the members /owners portion of the hd site as well. No big deal.
https://www.harley-davidson.com/cont...rs-manual.html
Dont freak out. Funny hard lesson, nothing more. If you are nervous about touching your bike. Go aahead a pay some guy to do it... but, i recommend you learn over indemnification. You are the guy who will be riding this thing in th middle of nowhere.
I say do it then have you work double checked this go round.
Consider getting a service manual.
Hello cvaria, thank you for responding.
I'm not freaking out, but would like to know why the adjustment bolt won't move in or out of the tranny cover when screwed/unscrewed in either direction. I have viewed Delroy's Garage video, unfortunately, until I get the adjustment bolt to move, I can't do much else.
P
P
P
P
John
P
Thank you for that Hotlap, an interesting procedure. I'll go to my Harley dealer and make sure that this is an option, if re-threading is required. They seem to favor replacement with new parts and in the case of a drive train cover, that would be very expensive. Will the gasket be reusable do you think? Has anyone installed an automatic chain tensioner and if so are you happy with it?
Thanks,
P
Hotlap- I love your Sporty pics, nice handlebars and pipes.
Thanks,
P
Did you loosen the locknut when you tried to readjust? Or are you turning the locknut and not the adjustment screw?
https://www.harley-davidson.com/app-...ER/file-7.html
Thanks for responding and encouragement. Normally, I don't have a problem with the routine maintenance. I had a brain fart, I guess, my other bike is a CCW Tha Heist which has a 27 mm (~1" hex head) for a drain plug. Duh!
Over the years, I've tackled only the basic maintenance, including fluids, basic wiring and battery changes, maybe I should spread my wings a bit.
