Stock seat "wiggles"
Old 07-28-2015, 03:41 PM
Bogie_71's Avatar
Bogie_71
Bogie_71 is offline
Default Stock seat "wiggles"
OK - this is probably a stupid question but I imagine a seat falling off would be a safety problem. Anyways, the stock solo seat on my 15 883N has a little bit of play if I wiggle it. The bolt itself seems secure so it is the seat. Is this normal?
Thanks
Old 07-28-2015, 04:26 PM
Kenny94945's Avatar
Kenny94945
Kenny94945 is online now
My 07 1200N does not wiggle.
The seat attaches easily so disassemble and have a look.
FWI - Perhaps the front mounting tang (mine is a pressure fit) needs some felt inserts, for example, to tighten it up. Not sure about this yet maybe your seat has rubber grommets/ bumpers where it sits against the frame and one fell off.
Should be an easy fix...good luck.
Old 07-28-2015, 04:31 PM
mrmarklin's Avatar
mrmarklin
mrmarklin is offline
Cool
Thanks
This is not normal. Have your dealer check it out under warranty.
Old 07-28-2015, 05:23 PM
Switchback12's Avatar
Switchback12
Switchback12 is offline
Best thing would be if it fell off! You can really have a more enjoyable ride with a good seat. But your seat should be snug.
Old 07-28-2015, 05:26 PM
Bogie_71's Avatar
Bogie_71
Bogie_71 is offline
Pulled it off (easy) and the metal part underneath the seat where the keyhole peg goes is pretty loose. I cranked on it pretty good and it didn't seem like it would come off but I'll probably take a ride to the dealer soon, or take them the seat and see what they say.
Old 07-28-2015, 05:28 PM
Bogie_71's Avatar
Bogie_71
Bogie_71 is offline
Yeah, was planning on upgrading it eventually but I guess maybe it will be sooner rather than later.
Old 07-28-2015, 05:37 PM
cHarley's Avatar
cHarley
cHarley is offline
Most of the popular aftermarket seats don't even have or use the keyhole plate and they aren't loose or wiggle. The problem is likely elsewhere.
Old 07-28-2015, 05:54 PM
Bogie_71's Avatar
Bogie_71
Bogie_71 is offline
Yeah, probably a combination of that and the slot where it slides in at the front having a loose fit. I could probably wrap it in some electrical tape or something and stiffen up the fit.
Old 07-29-2015, 07:56 AM
MightyY's Avatar
MightyY
MightyY is offline
The stock seat on my 15 XL883N wiggles quite a bit, too, but doesn't budge when I'm riding. I'd love to hear what the dealer has to say about it if you take it in.
Old 08-10-2015, 08:31 AM
Bogie_71's Avatar
Bogie_71
Bogie_71 is offline
Well I didn't ask the service dept. about it but I had to take my bike in on other issues and while I was waiting I wandered by the brand new 883's and tested the seats. They all wiggle. Mine was used so probably a little more broken in but like you said, when I am riding it doesn't move. I will assume it is "working as intended".
Quick Reply: Stock seat "wiggles"
