Oil dip stick cover
07-31-2015, 02:28 PM
Oil dip stick cover
Does anyone else oil dip stick sit sideways? If so is there a way to fix it?
07-31-2015, 02:52 PM
Is it just not turning all the way?
Post a pic?
07-31-2015, 02:53 PM
Would help to know what bike & year.....
07-31-2015, 03:34 PM
05 883
07-31-2015, 03:35 PM
The regular dip stick stuck out the same way. So I bought this one and it still does it.
07-31-2015, 03:45 PM
It needs another 1/4 turn than push down.
07-31-2015, 04:00 PM
Oil dip stick cover
Twist and push down
07-31-2015, 04:26 PM
I have the same one and the last bit is hard to turn, it helps if you put a bit of oil on the "O" ring before inserting.
Also if I'm not mistaken there is two spots that you can start it, try taking it out and rotating it 180 degrees and start there, hope that makes sense not sure how else to describe it.
07-31-2015, 04:28 PM
Quote:
Originally Posted by
saddleupmc
No push down on the temp gauge, just turns into place and that's it.
07-31-2015, 04:42 PM
+1 - it need another ~1/4 turn clockwise. The "ears" of the dipstick that you grab with your fingers should be inline with the bike frame.
