98 883 coughs at 2000 rpm
My 2000 Road King (EFI) does the very same thing. Big bore kit & Power Commander 1 installed when bike was purchased by selling dealer. I find it strange that this ONLY happens while holding a steady speed, and only occasionally. Current mileage is 74,000 miles, and now I pretty much just ignore this. no one can give me any real answer. One dealer thought it was excessive wear on throttle body, that really makes no sence.
I believe you already have your answer but the question is what do you do about it? 2000 rpm tells me one of two things - either you're lugging it or you are inadvertently describing a common issue - a partial throttle condition that is often solved by shimming the needle.
Questions:
How long has this happened? Sudden change or been that way?
What exhaust and intake do you have?
Any different jets than stock?
Have you opened up the mix adjusting screw on the carb?
What I'd do:
First check the plugs to see if they show signs of lean. Post a picture here if you can.
Determine how many turns out from lightly set the carb currently is. Adjust based on findings from the plugs.
If needed, dig into the carb to check the diaphragm for holes/tears (a bright flashlight works well), check what jet sizes you have and ensure they are all clean and clear of any buildup.
Shim the needle.
A Sportster likes the 3000+ range and loves the 3500-4500 range. Ride it hard.
Questions:
What I'd do:
Shim the needle.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
