Help - Drain plug confusion
Old 09-13-2015, 12:38 PM
Bluesrider.df's Avatar
Bluesrider.df
Bluesrider.df is offline
Received 1,659 Likes on 933 Posts
Default Help - Drain plug confusion
I don't have a service manual (yet). I want to change the Primary oil only, not transmission fluid, on my 2007 XL1200C. I thought I knew what I was doing, until I see two drain plugs and don't know which is which.
Can someone please ID these two plugs? Which is for what?
Old 09-13-2015, 12:55 PM
grapeapes's Avatar
grapeapes
grapeapes is offline
Never mind my comments I misread your post. just check your manual below...
https://www.harley-davidson.com/en_U...er/file-7.comp
Old 09-13-2015, 01:08 PM
Iarecobra's Avatar
Iarecobra
Iarecobra is offline
The one in the right is the drain plug. The one in the left is the primary chain adjusting nut.
Old 09-13-2015, 01:49 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
Sportsters share the primary and transmission fluid. There is no way to change only one as they are not separate sumps like a big twin.
Old 09-13-2015, 04:48 PM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
The one directly under the derby cover is the drain. If you are not going to adjust the chain don't mess with the other one.
Old 09-13-2015, 07:13 PM
Bluesrider.df
Thanks everyone. Fluid is changed, clutch is adjusted, test ride was a success.
Old 09-14-2015, 05:33 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Thumbs up
Well done, now get yourself that factory service manual! H-D produces probably the best there are and there is a stack of useful stuff in it - for those sleepless nights......
SDozier
07-13-2019 02:41 PM
Ibfuelish
11-01-2015 01:16 PM
crash1
05-25-2014 04:57 PM
crzrlou
01-13-2008 04:01 PM
so165
01-07-2007 03:02 PM
Quick Reply: Help - Drain plug confusion
