TSM issues on 06 sportster
Hi I am at a loss with my TSM for '06 883 sporty. The TSSM (68922-00D) went bad, I am fairly sure. The security was disabled. Replaced it with a used TSM (68920-01D). The bike starts, and dies immediately. I assumed that that meant I would need to "reset" the TSM or possibly "marry" it to the ECM.
I cannot find any resetting or marrying information anywhere. Does anyone know the procedure or have any other suggestions?
Important to note: Prior to changing the TSM/TSSM, Turn signals, horn, odometer, speedo did not work. the red key (security) light was always on. Bike started and ran fine, however.
post TSM swap: same symptoms on the speedo, odometer, and signals. Red key light never on.
you may try the procedure found in the second page here:
http://www.harley-davidson.com/en_US...ts/-J03513.pdf
but in a non-harley service manual, says the tsm and tssm are not interchangeable...not sure how to interpret that...
good luck!
good luck!
put the old tssm, and see if the bike starts, like it did before the swap...
then try to do the procedure to retrieve dtc...
https://www.hdforums.com/forum/sport...des-dtc-s.html
anubisss
02-11-2007 06:02 PM
