Rear turn signal to brake light bulb question
Old 11-04-2015, 11:11 AM
WiscoKid's Avatar
WiscoKid
WiscoKid is offline
Default Rear turn signal to brake light bulb question
I'm changing out my rear turn signals to brake lights and turn signals. I have the kit from Harley with the red lens covers. Do I need to use a different bulb like a dual filliment bulb? Or can I use the 1157 or 1156 single filliment? Just wondering what bulb I should be using with this kit? Bike is a 2007 1200c
Old 11-04-2015, 06:53 PM
hscic's Avatar
hscic
hscic is offline
In the absence of replies....here is my input based on my experience. Not sure what is included in your kit, but normally dual purpose lights need dual filament bulbs. I did read somewhere that you can use a single element bulb but the kit needs to modify the current so the light can change intensity. I have a single element LED on my saddlebags and tried to use them for dual purpose - running and brake. Installed a converter harness but it did not work...the wires got extremely hot so rewired and use them as additional brake lights.
Old 11-04-2015, 07:00 PM
Sammi's Avatar
Sammi
Sammi is offline
I have the kit and use the same bulbs as before. No change to bulbs.
Sammi
Old 11-04-2015, 07:08 PM
Dragginboards's Avatar
Dragginboards
Dragginboards is offline
Before I went LED, had that set up from HD. Used same bulb, worked great
Old 11-04-2015, 07:10 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
I have the same year & kit & the HD kit worked perfectly and uses the stock bulbs.
I already had the smoked lenses so I wanted to use red bulbs, I tried red LED bulbs but they wouldn't flash properly so I got red incandescent bulbs from Kuryakyn.
I also wasn't quite happy with how obvious as brake lights they were to distracted cages behind me so I kept the brake wire (bypassed the converter box) and installed a LED brake light bar up by the licence plate. If I did it again I'd get the fender lip LED brake light they have now I think on the Nightster, they didn't have them when I did my conversion.
Old 11-05-2015, 08:55 PM
t100rc's Avatar
t100rc
t100rc is offline
maybe read the instructions in the kit ... just sayin' ...
seriously, though ... the 'box' that plugs into the lighting harness uses your existing single filament bulbs but just regulates the power to them so that they ACT like dual-filament lights. This device is usually referred to as a "Run-Brake-Turn" module.
You can't put dual filament bulbs in your light housings without gutting them and replacing the sockets with dual filament sockets or buying new bullet lights that are pre-wired for dual filament bulbs (like the ones on a Nightster) ...
Old 11-07-2015, 04:19 PM
WiscoKid's Avatar
WiscoKid
WiscoKid is offline
Instructions say nothing about changing bulbs. I put the 1156 bulbs that are single filament and it does work as it should.
Thumper26
06-30-2012 07:10 PM
acd118
10-03-2011 11:54 AM
oc1014
08-22-2011 12:21 PM
titus3:5
10-06-2009 11:07 PM
Motown_HOG
07-14-2008 01:47 PM
Quick Reply: Rear turn signal to brake light bulb question
