Increase lean angle
Increase lean angle
Hey guys,
I checked my iron 883 out today and discovered that at some point I leaned far enough to scrape the metal right peg off from under my mid mounted controls. I'm actually scraping the exhaust in some turns. I did a track day this summer and I guess it made me a bit too confident leaning my bike... Is there anything I can do to increase the amount of lean angle I can get out of my bike before I start scraping hard parts again? Either way, I'm thinking I'm riding too aggressively at this point...
Thanks in advance,
Jea
Thanks in advance,
Jea
First option is get a higher exhaust. Like the high pipes that run between your leg and the oil tank. Second option is to get longer shocks. I am a too short so I went the first route. If you get different suspension I doubt you'll miss the stock setup anyway. I just lean in till my pegs scrape then I back off a bit. But if you're short like me once you move the exhaust the first thing to touch on either side will always be the pegs so you won't be in too much danger when they drag.
Yes, there is. You can make enormous improvement, that is, reducing, the lean angle by changing your torso position.
When you're about to enter the curve, relax your upper body, lean forward, and lean your torso INTO the curve. You want your body to lean MORE than the bike. You absolutely do not want your body to be above the bike, you want your body to be below or inside the bike. This will cause the bike to lean less, which is what you want, and you'll be much, much less likely to drag things.
A simple way to do this, explained to me by a motor cop, is to move your chin toward the inside rear view mirror, and always keep your chin level.
Here are two good/bad posture pics: The first is good, the second is bad.
GOOD:
BAD:
GOOD:
BAD:
You know what's funny about your pic? You have sparks flying because you ride aggressively too! HA! Good stuff! I absolutely reposition my body to redistribute the bike's center of gravity, but as you know, it's not a sport bike. Which is good. There should be no knee dragging on public roads. I'm just gonna raise the bike up a bit, get whatever else I can get out of the bike, and enjoy my cruiser for what it is.
Oh, and another thing, do NOT try to countersteer a motorcycle by pushing on the inside handlebar. Why on earth would you try to turn a 600 pound, 700 pound, 800 pound, 900 pound motorcycle with ONE hand? That's crazy.
Always, and I mean always, use both arms. Relax, lean forward, lean in, and push with the inside arm and PULL with the outside arm.
You won't believe how much easier, smoother, and more controlled your turns will get.
Trust me. Try it. You'll become a believer.
I'm just giving you ways to enjoy riding your bike, without changing anything, except your understanding and your skill level.
Ride safe!
(Oh, that ain't me in those pics! )
